588,219 active members*
4,152 visitors online*
Results 1 to 11 of 11
    Aug 2011
    19
    Lathe turn-mill
    Our company bought a Doosan Puma 2100LSY lathe with subspindle and Y-axis and alsa Mastercam X6.
    I'm trying to turn a part that has a radius milled on one side (see attached picture) but I cannot make the right toolpath for milling.
    Any help is appreciated.
    Dec 2008
    3137
    This is a normal milling operation, with the part being held in a 3 jaw chuck
    use a
    2D_Contour, WCS=TOP, T&C plane=FRONT
    Geometry is an arc in the XZ plane, that ( when projected each way ) would slice the bar to leave your model, & extend the geometry arc ends a little bit.
    Depth cuts, as required
    cutter is flat endmill, flute length greater that depth of cut, & needs to stickout of the holder more than the diameter of the job, cutter diameter must be same or larger than the tool shank ( leaves rub marks )
    try using 2 ops instaed of Multi-passes, 1st for roughing, 2nd for the finish pass(es)
    ( gotta walk before you can fly )
    Your machine will have limited Y minus travel, so do a lead in ( tangent ), lead out (perpendicular )
    Aug 2011
    19
    Using the FRONT plane gave an error - A valid cut type was not found, check rotary settings.
    Using the BACK plane posted fine but this code can't be right.
    (TOOL - 4 OFFSET - 0)
    ( 10. FLAT ENDMILL)
    G0 T0400
    G19
    M23
    G0 X202.178 Z20.592
    M35
    C8.417
    G97 S2500 M3 P12
    X35.719 C55.949
    G98 G1 X34.153 C60.058 F531.
    X32.791 C64.492 F578.5
    X31.65 C69.24 F624.3
    X30.746 C74.269 F665.9
    X30.096 C79.532 F700.4
    X29.71 C84.957 F724.9
    X29.595 C90. F737.
    G42 X36.654 Z11.235 F500.
    X37.198 Z10.406
    X37.595 Z9.557
    X37.843 Z8.693
    X37.939 Z7.822
    X37.884 Z6.95
    X37.676 Z6.084
    X37.318 Z5.23
    X36.813 Z4.395
    X36.164 Z3.585
    X35.376 Z2.807
    X34.456 Z2.066
    X33.41 Z1.368
    X32.247 Z.718
    X30.974 Z.121
    X29.602 Z-.418
    X28.142 Z-.896
    X26.604 Z-1.307
    X25. Z-1.651
    X21.987 Z-2.181
    X18.93 Z-2.642
    X15.834 Z-3.034
    X12.706 Z-3.356
    X9.552 Z-3.607
    X6.379 Z-3.786
    X3.193 Z-3.894
    X0. Z-3.93
    C270. F2000.
    X3.193 Z-3.894 F500.
    X6.379 Z-3.786
    X9.552 Z-3.607
    X12.706 Z-3.356
    X15.834 Z-3.034
    X18.93 Z-2.642
    X21.987 Z-2.181
    X25. Z-1.651
    X26.604 Z-1.308
    X28.142 Z-.896
    X29.603 Z-.419
    X30.974 Z.12
    X32.247 Z.717
    X33.411 Z1.367
    X34.457 Z2.066
    X35.377 Z2.807
    X36.165 Z3.585
    X36.813 Z4.395
    X37.319 Z5.23
    X37.677 Z6.084
    X37.884 Z6.95
    X37.94 Z7.822
    X37.844 Z8.693
    X37.596 Z9.557
    X37.199 Z10.406
    X36.654 Z11.235
    G40 X29.595 Z20.592
    G0 X202.178 C351.583
    G0 Z20.592
    G28 U0. V0. W0. H0.
    M5 P12
    T0400
    M30
    Dec 2008
    3137
    You seem to be using either the rotary axis ON or using a lathe plane
    ( could geometry be 90° out of position ? )
    What code do you get if WCS=TOP, T/C plane = TOP, & geometry drawn in TOP view ?
    like programming for a milling machine,
    You should be getting YZ outputs, with X controlling the depths, & C being defined as a positioning axis at the startup only
    Aug 2011
    19
    Using the TOP plane also gave an error - A valid cut type was not found, check rotary settings.
    Aug 2011
    19
    My Mastercam rep told that the post processor is the culprit. Seems a bit odd since one of the reason for buying mastercam was the fact that they told they have the right post processor for my machine.
    I guess if they can't provide a working post (and I'm stuck with mastercam) I'll have to find someone to customize the post processor.
    Jan 2013
    20
    They wont edit the post so you have what you paud for?
    Jan 2012
    I don't know mastercam as we use Creo (Pro/E). The Y axis shown in your pic would need be defined as the Z of the sequence coordinate system to generate the toolpath I believe your trying to create. (The +Z of the csys needs to point toward the + direction of the tool axis or toward the spindle).
    Jul 2011
    218
    Quote Originally Posted by kopsik View Post
    O they can provide a working post
    But its gonna cost ya
    CHOCLATE? THIS IS DOODOO BABY!
    Aug 2011
    19
    They are trying to edit the post, but it seems that they are having some difficulties and it's taking them forever to do it.
    Apr 2003
    3578
    Have the check with in-house solutions they may all ready have one.
    Cadcam
  1. Fanuc mill turn lathe post needed!
    By jake_tb in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-10-2013, 03:26 PM
  2. Replies: 4
    Last Post: 05-01-2013, 01:05 AM
  3. MachStdMill Turn and Mill-Turn Announcement
    By mvcalypso in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-16-2012, 03:38 PM
