588,127 active members*
5,172 visitors online*
    Aug 2013
    28
    These mill bits any good?
    Looking to up from 2 flute to 4 flute when cutting hardwood. I typically drill pockets and have to ramp about 10 passes to finish each pocket. It's slow, but works.
    5 Pcs YG1 4 Flute 1 4 End Mill Solid Carbide TiAlN Coated x 3 4 x 2 1 2 CNC Bit | eBay
    Apr 2004
    5755
    Re: These mill bits any good?
    Usually, 2 flute bits are better for wood. 4-flute bits work best in steel. What makes you think that you need more flutes?
    Andrew Werby
    Website
    Aug 2013
    28
    Not really sure. The 2 flute carbide bit seems to stress a bit running at half the SFM it should based on chip load calculations. That and the spindle I'm using runs at Max 12000 RPM. Thought going 4 would give me a little more wiggle room in getting that desired chip load without stressing the machine. I'm guessing its stressing due to occasional vibrations I'm getting during cuts. Trying to hit the sweet spot.
    Sent from my cm_tenderloin using Tapatalk
    Aug 2013
    28
    Actually, the 4 flute seemed to work okay, not as good as the 2 flute bit I'm afraid. Vibrations are worse. Should I even go as far as looking for a single flute or even a rounded bit? I'm using the Shapeoko (Version 1) build so the Z axis isn't the stiffest, but I've added a bit of re-enforcement to it to help with that. I go slow enough so it doesn't flex, but I still get vibrations here and there, sometimes it vibrates the whole table and can get loud.
    Jun 2009
    267
    Sounds like you may have some binding issues. If its making alot of racket when cutting something is binding up somewhere. Check everything then check it again to make sure. Sometimes the slightest adjustment can make the biggest difference.
  1. Cnc end mill bits
    By DistortedDesign in forum Want To Buy...Need help!
    Last Post: 11-16-2014, 06:27 PM
  2. Router Bits from China, Good or Bad?
    By Andrew B in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-16-2011, 01:58 PM
  3. Need good source for cnc router bits
    By IQChallenged in forum Charter Oak Automation Support Forum
    Last Post: 03-14-2008, 05:27 PM
