588,193 active members*
7,609 visitors online*
Results 1 to 7 of 7
    Sep 2005
    5
    CRS 1018 Tooling Help
    Hi everyone.
    I am having trouble getting a good finish when turning 1018. Part is 1.25" dia by 9.25" long. Turning down to .75 " 8.5" long. I am having slow way down to get a chatter free cut resulting in a crap finish.
    I found a few threads related to my problem, and people said to use a positive insert. So my question is, do they mean an insert with a more positive chip break or a positive rake tool holder.
    I am currently using a MCLNR with a CNMG431MP. This works great for 1018 when part is robust and can keep the speed up.Thanks for any advice/help you guys can muster.
    Jesse
    Aug 2008
    43
    thats cause cold roll sucks for finish! positive chip breaker!
    May 2007
    1003
    Use both. The two combined should let you increase RPM a bit. Go with a ground insert. Preferably a cermet. Hard to get a good finish with too slow of an RPM. Use oil if possible.
    Jan 2004
    3154
    It is likely because your part is expanding (thermal) and your tailstock is forcing it to orbit.
    I find that it helps to leave the tailstock spindle unlocked and leave the pressure at absolute minimum.
    What you are doing is PITA.
    www.integratedmechanical.ca
    May 2007
    1003
    I assumed a cnc lathe. Which type are you using?
    Sep 2005
    5
    It is a Haas SL-30. Thanks for the replys. I have some 12L14 coming today to get me through this part. I will definately be ordering some positive tooling though for the future.
    Thanks again.
    Jesse
    Mar 2006
    if you lookin for good finish when turning you could try using wiper inserts with a light chipload
  1. Figuring Torque needed to tap a 1x8 thru 1018
    By doug9251 in forum Mechanical Calculations/Engineering Design
    Last Post: 08-06-2008, 02:05 AM
  2. RFQ: Turn / Mill work needed 2" dia 1018
    By dsmdude in forum Employment Opportunity
    Last Post: 09-27-2007, 03:59 PM
  3. 1018 Round Stock in SE PA
    By buckkillr8 in forum Employment Opportunity
    Last Post: 08-06-2007, 08:55 PM
  4. Drilling question 1018 and 4140
    By schiada96 in forum Uncategorised MetalWorking Machines
    Last Post: 11-27-2006, 05:45 PM
  5. Turning 1018
    By mjarus in forum Mini Lathe
    Last Post: 06-23-2006, 03:46 AM
