588,232 active members*
4,744 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco KM3 3 phase to single phase conversion
    Mar 2024
    12
    Hi, I have Hurco KM3 and I wish to convert it to single phase.
    At the moment I have chosen the VFD route, utilise the servo side of the machine to single phase and use the VFD to run the 3 Horsepower spindle.
    Has anyone gone down this route, and any advise on this or different options
    thanks for any help on this subject
    macdave
    Apr 2009
    22
    Re: Hurco KM3 3 phase to single phase conversion
    Ok, where I am currently,
    I have connected single phase 240V to L1 Line in and Neutral 0V to L2 Line in and ignored L3 as it is connected to the 3 phase spindle and flood coolant which is 3 phase. The control has booted up but when I get to the Power on there is no flashing light and I cannot calibrate the machine.
    Any ideas anyone, thank you.
    Nov 2013
    4603
    I rather suspect that there is an interlock that prevents the control from operating until the three phase components are properly powered.
    It could be something like a phase rotation/phase missing relay. The affirmative output of that relay is required before the control will complete its boot up.
    Craig
    Apr 2009
    22
    Hi Craig,
    thank you for that, ill see if I can find a drawing showing relay connections from the spindle. I had disconnected the spindle and the coolant pump, both 3 phase, from the relays to try and bypass that. From your thoughts I made need to put a feed to a relay that would normally come from the circuit of the spindle. I presume you looked at the wiring schematic above and couldn't see any thing that might do that.
    Dave
    Apr 2009
    22
    Just following up on the post about looking for a relay receiving a signal via the spindle, I have looked at the diagrams and have failed to see anything which might point to a connecting relay. I was given a lead, that it could be a problem on the Personality Board itself, as you can see there are 16 of a particular type of chip, H11G2, these are Photodarlington Opto Couplers (High Gain Switch's). As you can see, it appears 2 have been changed in the past. The board shown below is my old board, I have highlighted the couplers.
    Rather than look for replacement parts I decide to get a backup board, So, I managed to obtain another board, shown below, it is slightly different but apparently should do the same job. The only issue is i need a Hurco Service Document which shows me the settings for the DIP switches and the Jumpers.
    Alternatively, if anyone has one of these boards fitted to their KM3/P, could you take a look and take a picture of the DIP SWITCHES and JUMPER settings so I could copy them, thank you for your help on this issue.
    Attached Thumbnails Attached Thumbnails KM3 Electrical (128).jpg   KM3 Electrical (130).jpg
  1. Replies: 29
    Last Post: 02-12-2022, 09:20 PM
  2. Replies: 1
    Last Post: 04-18-2020, 04:35 AM
  3. Robodrill 7.5hp spindle. Single Phase Power input No Rotary Phase convetor doable?
    By whiteriver in forum CNC Machine Related Electronics
    Last Post: 01-05-2017, 09:01 PM
  4. Replies: 2
    Last Post: 09-24-2015, 07:04 PM
  5. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
