588,620 active members*
5,003 visitors online*
IndustryArena Forum > CAM Software > Mastercam > rotary 4 ax depth of cut q.
    Aug 2003
    812
    How do you adjust the depth of cut in a rot 4ax tool path? My stock is larger than my part by 1 inch to allow for the part size, and the tool path keeps plunging to the part surface to begin cutting. I've adjusted the absolute cut depths setting min and max, tried incremental, doesn't seem to get me what I want. I'd like it to start at z2 and cut 0.1 depths down to the surface.
    I seen a 4th axis training tutorial but no explaination of how to adjust the cut depths.
    Aug 2003
    812
    Wow I thought this would be an easy one to answer, no answer at the Mastercam forum either.
    Apr 2003
    3578
    Sorry but there is not a way to do this at this time.
    Usally What I do if needed is create one then leave stock then copy and lesen the stock left.
    I have not checked this in MC "X" yet but I am now.
    Cadcam
    Aug 2003
    812
    Oh.....I just ASSumed there was some sort of way to creep down to the part surface.
    Thanks a lot for the reply, I was pretty much driving myself nuts trying to get the software to do this.
    Your method will work sounds like though.
    dave
    Apr 2003
    3578
    Also have you figuerd how to get the path to start from another direction.
    say from the left and not alwas the right?
    Hope that helps
    Cadcam
  1. Kcam Cut depth
    By 47MLB in forum Uncategorised CAM Discussion
    Last Post: 01-18-2012, 08:04 PM
  2. cut single, cut auto and cut all???
    By fastolds in forum BobCad-Cam
    Last Post: 10-06-2004, 02:15 PM
  3. PICS - BOAT HULL CUT WITH CNC
    By ninewgt in forum DIY CNC Router Table Machines
    Last Post: 08-03-2004, 12:21 AM
  4. Another feed rate, cut depth question
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 02-10-2004, 06:56 AM
  5. Can you cut Al. with a wood bandsaw
    By CactusChip in forum MetalWork Discussion
    Last Post: 11-20-2003, 10:45 PM
