588,537 active members*
4,720 visitors online*
    Mar 2005
    159
    Timing belt drive
    I've seen plenty of timing belt drives where there is a belt on each side of the X axis and the pulleys are tied together with a shaft.
    How about a single timing belt in the middle?
    Would it work?
    James
    Nov 2005
    53
    It would.. center drive necessitates a quite stiff gantry to avoid racking under load, but it is the same problem with single screw drives.
