588,529 active members*
7,231 visitors online*
Results 1 to 7 of 7
    27
    Set G30 macro issue
    Hi all... Machine is Daewoo Puma 2100SY FANUC 32i control. Trying to set secondary home for tool changes both on main and sub spindle. Having 2 separate issues. I have a macro program that we use in another Puma but with 18i control:
    O9999(SET G30 FROM CURRENT POSITION)
    #100=[#5021*25.4]
    #101=[#5022*25.4]
    #102=[#101*1000]
    #103=[#101*1000]
    G10L50
    N1241P1R#102
    N1241P2R#103
    G11
    M30
    Issue when running this (besides having to change G10L50 to G10L52) is that after I run this it the value entered into the parameters is way off..
    N1241 X axis, machine pos. 13.289 after running should be 337.54. Actually comes up as 857.354
    N1241 Z axis, machine pos. 6.7594 after running should be 171.696. Actually comes up as 1177.287
    Somewhere the calculation is off or possibly I am using the wrong system variable for machine pos.??
    I can work around it by entering the values manually into parameter 1241 for safe tool change to use for both spindles, and using 1242 for the main side and 1243 for the sub side.
    OK, now issue # 2 I am having...when I either in MDI or in the program use G30 U0 W0 it goes to the home position, however when I enter G30P3U0W0, I get an alarm "46 - ILLEGAL REFERENCE RETURN COMMAND" same result with G30P4U0W0.
    Any ideas or suggestions?
    Thanks in advance!
    Jun 2007
    119
    Issue #2
    use G30P2U0W0 after you sett param. 1241
    G30P3U0W0 set param. 1242
    G30P4U0W0 set param. 1243
    Issue #1
    Why convert inches into mm [#5021*25.4] ?
    #5021 1st axis current position machine coordinate system
    #5022 2nd axis current position machine coordinate system
    #5041 1st axis current position workpiece coordinate system
    #5042 2nd axis current position workpiece coordinate system
    2932
    This one works on the 31i and 0i model D
    #101=#5021*10000
    #102=#5022*10000
    G10L52
    N1241P1R#101
    N1241P2R#102
    G11
    M30
    G30 P3 and P4 are options that aren't activated on your machine?
    Sep 2005
    281
    Re: Set G30 macro issue
    I know this post is old but did you fix the Problem? I'm having the same issue. thanks
    Nov 2007
    364
    Set the Parameters Manually and set up a G-Macro program like a G203 and -----Way to complicated
    Sep 2005
    281
    Yes I Did set up a G-Macro Called it G130, It Works but the numbers it puts in 1241 are wrong? Same as dcrace Stated.
    Nov 2007
    364
    Picking up other numbers so try canceling stuff or just sending figure to a Macro to confirm what you are seeing
  1. issue with corner finder macro
    By cmg in forum Mach Wizards, Macros, & Addons
    Last Post: 12-03-2013, 05:18 AM
  2. Replies: 2
    Last Post: 12-19-2012, 01:28 PM
  3. Replies: 3
    Last Post: 02-13-2012, 07:20 PM
  4. Replies: 2
    Last Post: 03-27-2009, 09:15 PM
  5. Mazatrol Macro callout issue
    By MrMazak in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-25-2008, 02:11 PM
