![Quote](images/misc/quote_icon.png)
Originally Posted by
One of Many
Not surprising if it is mild steel 3' of rolled thread. Hardened and Ground, I'd expect better of. Chances are you might get no better, no worse in exchange unless you spec it with additional charges if they offer selective tolerances or straightening services.
1/2" over 3 ft should bend easily. I have straightened 3/4 with a rubber mallet in a lathe chuck advancing it out 1 foot or less at a time, flipping it end for end just past half way out. The stuff is soft enough to make run true on center. Worked goodnuff for my needs on a 3' drill press table jack. But then, it weren't spinning at 1200rpm either.
DC
