Originally Posted by
rahilm
I have a custom build CNC plasma. It works pretty well for simple art cuts, but I'm really having trouble getting good cut performance for more precise parts, especially for thicker aluminum. For example, in 1/4" 6061 aluminum, I have at least a 1/16" taper on cuts, which is much worse than what I've seen done by other people.
The software I use is Mach3 and SheetCAM. I've set most of the parts to use perpendicular lead-ins and radial lead-outs, which I understand is optimal. All the feedrates I use currently are best quality settings as per the Hypertherm manual. I use a THC system to manage height, and it seems to be working as far as I can tell. I use ohmic sensing to find the top of the material, and that works consistently.
What I'm wondering is what accelerations, speeds for the z-axis, and maybe other SheetCAM settings I need to use to improve performance.
Thank you.
