2011 v7 vertical machine center by SyiL
We present new 2011 v7 machine center.all syil dealer in stocking,delivery time within 3 months include china new year.
Features
Siemens 802s system,3 axis servo package.
5.7Inch single blue LCD display screen, showing spindle speed and direction and movement size
Panel focused on manual control systems, cooling and spindle control
3 axis servo motor,siemens original
spindle servo motors. 2.2KW.
800 X 250mm Size of table
10000rpm/min High Speed Precision Spindle,NSK bearing.
380V single-phase AC power supply
BT30 spindle
10pcs ATC system with draw bar
2 x 120mm pre-installed high-speed cooling fan
high quality casting materials, compact structure
OEM PMI double nut ballscrews
Hiwin precision linear guideways
safety of high-quality electrical components and fast plug
the integration of the base casting
Automatic lubrication system pre-installed to protect the rail life
Coolant/working lights pre-installed
MPG handwheel controller pre-installed
CE and CCC safety certification
Features
Overall Demensions(L x W x H)***** * - 1550mm*x*1650mm*x*2300mm
Packing Demensions(L x W x H)****** - 1650mm*x*1850mm*x*2400mm
Table size*********************************** * - 800mm x 250mm
T Slot Demensions********************** ** - 16mm
Weight******************************************- 1200~1350kg
Axis travel************************************* - X axis: 400mm
************************************************** * - Y axis: 240mm
********************************************** **** - Z axis: 400mm
Spindle speed**************************** ** - 200~10000rpm/min
Spindle drive power********** ************ *- 2.2kw Servo
Spinble taper****************************** * - BT30
Input voltage***************************** ** - 220v AC 3 Phase
Repeatablility**************************** ** -≤0.01mm
Cutter dia*********************************** *- 4~16mm
Motor torque************************* ****** - X axis motor: 8.0nm
************************************************* *- Y axis motor: 8.0nm
**************************************** ********* - Z axis motor: 8.0nm
Direction,Commitment,Follow through
