![Quote](images/misc/quote_icon.png)
Originally Posted by
itstom
As near as I can tell this hasn't been asked for a couple of years so I'll throw it out there. Can the spindle of a Haas ( or another brand mill) be synchronized with the A axis? If the spindle can be synced to the Z axis for rigid tapping, why not the A axis? Are there hardware issues I don't understand or is it simply a matter the software?
Thanks, Tom
Your question is not real clear.
If you are comparing the rigid tap of the Z axis, it needs to be noted that rigid tap uses a separate encoder for the spindle and added software.
If you enter the correct A diameter in the graphics section and do Z and A movements, they can be coordinated.
Is that what you are asking?
Mike
