588,529 active members*
6,677 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > as anybody ever heard of the cybaman replicator
Results 1 to 8 of 8
    Jul 2005
    969
    i found that more then nice machine on paper the other day as anybody ever saw or work with it
    http://www.cybamantech.co.uk/cyba/cyb.php?page=cybaman the also sell the axial arm i think individualy
    Mar 2006
    357
    That is a pretty neat machine. But at a base starting price of $119,000.00 I may have to wait until my lotto numbers hit.:banana:
    Steve
    Jul 2005
    969
    here is an email i got from them
    Hi Felix,
    Sorry for the delay in answering
    Many thanks for your kind enquiry relating to the Cybaman Replicator.
    The machine was originally developed for Engineering application's but
    was adapted for Jewellery use, under a Project for the School of
    Jewellery at The University of Central England in Birmingham UK.
    The concept behind it was to provide Jewellers with an Automatic machine
    they could use without having to learn Engineering Machinist skills. All
    that is required of the operator is to learn how to construct a 3D
    computer Model in Hyperll/CAD the Software package. This software will
    also generate the process tool cutting path automatically by selection.
    Once loaded with material and the program path the machine takes
    control, machining a copy of the computer model three dimensionally both
    inside and out in one operation.
    The Jeweller who participated in the technology transfer project was
    Alfred Terry in London. They took the prototype approx 5 years ago the
    now have three of our machines all operated by one man.
    Please see the _case study Alfred Terry _on our web site for more
    details of this. Installing the system had profound effect on their
    production: originally intended to produce Masters it became easier and
    quicker for them to machine directly from precious metal tube and to a
    large extent they stopped Investment Casting.
    The Cybaman is a very versatile and powerful machining system in
    miniature. The basic machine has a component envelope of 150 x 150 x
    150mm with 50,000 rpm 2.2kw spindle with pneumatic draw bar providing
    for manual tool change.an on board quiet running air compressor, water
    chiller for spindle cooling and mineral oil mist lubrication coolant.
    There are options for 6 station ATC, and various laser line scanning probes
    The Hypermill 5 axis software bundle costs £14,885, we are however
    offering incentives by way of discounts on Hardware & Software to
    promote this new technology.
    The 6 axis CNC Machining System has been developed to rapidly
    manufacture functional metal components, directly from a component’s
    computer model, three dimensionally. It actually replicates the computer
    model, simplifying the manufacturing process, using robotic three
    dimensional component presentations. This allows manufacturing
    operations to be undertaken, without having to reset position. It
    provides a total system solution to automatically machine complex shaped
    parts directly from a computer model, in 'one hit'. from metal, wood,
    plastic or any machinable material.
    The machine has six degrees of freedom (3 linear + 3 rotary) allowing
    complete freedom of movement in Cartesian space. It has been developed
    specifically for manipulating components three dimensionally against a
    process tool. This is achieved using the continuous instantaneous
    centre, created at the intersection of its rotary axes, as a 3D “real
    world” datum to emulate the “virtual world” Cartesian datum in the CAD.
    It can in fact machine a "golf ball" on a "tee" since it provides access
    not only to the top four but also to the lower four quadrants of a sphere.
    This takes it beyond 5 axis machines into a CNC machine controlled by a
    post-processor that has a primitive intelligence built around the
    mathematics’ of the manipulator's movement algorithm. Superimposed rules
    of behaviour written over this algorithm actually turn it a robotic
    system. This simplifies programming and removes the requirement for a
    skilled machinist, enabling operation by personnel having only knowledge
    of CAD.
    We advocate the use of HyperCad machining software which generates a 5
    Axis cutter path APT file of the model's surface. This is then post
    processed through our Cybasoft post processor to produce a G code
    programe made up of 6 axis moves and feedrate automating the whole
    machining Cycle.
    Productivity Benefits:-
    v Eliminates fixtures and their cost.
    v Eliminates “setting-up time”.
    v Eliminates “down-time” between operations, reducing time to
    manufacture, manufacturing costs, Increasing productivity.
    v The system is ideal for large or small batch component production
    and being robotic, is re-programmable for production of other components.
    v It can also be used as a 3D digitiser and may be fitted with
    alternative process tools.
    Should you require a more detailed quotation please let me know.
    Best Regards
    Joe McLean
    Managing Director
    Cyba Manufacturing Technology Ltd
    Unit 5 Hattersley Ind. Est.,
    Stockport Road,
    Hyde,
    Cheshire
    SK14 3QT
    Tel: 00 44 161 367 8789
    Fax: 00 44 161 367 8785
    Oct 2005
    278
    this machine is too nice
    i think i'm replacing my workshop pin-ups man
    sure like too see what kinda part really NEEDS 6-axis machining
    Sep 2010
    what kinda part really NEEDS 6-axis machining??????
    See 6 axis fully synchronised machining.
    [ame="http://www.youtube.com/watch?v=gvJmIP4OCIE"]Cybaman Dental Milling System - Cobalt Chrome Bridge Machining - Finishing - YouTube[/ame]
    Aug 2009
    986
    Quote Originally Posted by manipul View Post
    Interesting design.
    It's my understanding that a 5 axis setup can achieve any possible angle. Watching that video, I can't see any clear reason for the "elbow" midway down the arm.
    It's an impressive machine. I just can't figure out why they built it the way they did. Can anyone enlighten me?
    Frederic
    Apr 2005
    862
    You are right, however they may have added the extra joint to move or remove singular points in the motion, where a tiny angular change equates to a large movement on the work piece for example. Maybe also to get the range of motions needed in a smaller machine volume. Either way, from a pure geometric standpoint the 6th axis is redundant. In my opinion for dental applications like the one shown above it is very difficult to justify anything other than 3+1 axis milling. These 5+ axis machines are much more expensive and the products they are producing are pretty low value anyway. You do need them for implant supported bridge structures though.
    LongRat
    www.fulloption.co.uk
    Oct 2010
    266
    damn. id like to see the paycheck the guy who programs that machines gets
