587,597 active members*
3,729 visitors online*
    Sep 2009
    6
    Maho 600 cnc432 major problem
    Hello the next problem has occured with a maho600.
    When i turn on the power the display shows some parts of text on the screen.
    On the upperleft is "manual" and the upperright is only a "2".
    Below there is says MAN-OP and where the axis are there are a lot of zeros and a big value. the G- and M-codes are also displayed.
    I cant get in speicher (memory) mode.
    But when i remove the diagnosis-card i can see the in and outputs.
    I already extracted all the ic's and cleand them.
    Cleaned the backplane and the panel.
    So i dont know what to do anymore.
    regards
    Jitze
    Nov 2007
    www.MahoDoctor.com
    send photo
  1. Maho MH600E - CNC432 Data transfer problems
    By Grusse in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-20-2021, 11:31 AM
  2. Drip feed with MAHO 600E-Phillips cnc432
    Last Post: 10-20-2010, 09:52 AM
  3. MAHO-PHILIPS 432 M60 and G23 problem
    By micktat in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 03-03-2009, 11:10 PM
  4. Maho 800E Toolmagazine problem
    By kotten1 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 02-20-2009, 10:13 PM
  5. Major problem using Xylotex Box
    By Smertrios in forum Benchtop Machines
    Last Post: 03-11-2006, 06:55 PM
