586,398 active members*
3,024 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Question about locline for BF20 machine
Results 1 to 11 of 11
    Jun 2005
    45
    Hey all, I am setting up a flood cooling system for my BF20 mill (G0704 for the US).
    I am just wanting some advice on the size of locline that others have used for smaller flood systems. I was thinking of 1/2", but since I need to ship it all the way to Australia from the US I wanted to make sure it is right!
    Cheers,
    Scott
    Mar 2009
    296
    I was just looking at this site Loc-Line World I didn't realize this same stuff has a lot of other uses like for aquariums, dolls, stuffed animals, snakelites and showers. You might be able to find something in a dumpster to get it from for free! Now I'm wondering how well an automotive electric fuel pump would work out pushing the fluid through it?
    Feb 2008
    521
    Quote Originally Posted by slashmaster View Post
    It wouldn't - most automotive fuel pumps (EFI) have submerged electrics ie. the rotor / armature is within the fuel path. Water and electrics as you know don't work well together. Could use a diaphragm pump but they are usually low flow and noisy !
    Jun 2004
    6618
    I do use a submerged pump myself. It was a solvent tank originally. It works fine.
    An automotive fuel pump might be too strong. I think they are at least 90 PSI. Strong enough to put an eye out for sure.
    Just about any small pump can be used if used as designed. Plenty of cheap ones available. Aquarium stuff, garden stuff, fountain pumps, solvent tanks etc.
    I even have a small pump that attaches to a drill and a couple water hoses to pump stuff with.
    Lee
    Aug 2009
    899
    Quote Originally Posted by CADScott View Post
    Cheers,
    Scott
    go with 1/4" This is the most commonly used line and what a lot of others are using. I am also using it on my ZX-45. Also here is a good cheap source for the Loc-Line product. ModularHose.com - Loc-Line Modular Hose System
    Jun 2004
    6618
    This is what I bought.
    ADJUSTABLE COOLANT HOSES WITH MAGNETIC BASE NEW - eBay (item 160531744241 end time Jan-19-11 23:51:43 PST)
    Not sure if he ships down under, but you might check Aus. Ebay.
    Lee
    Feb 2008
    521
    Quote Originally Posted by LeeWay View Post
    Maybe I should have made it clearer! Auto pumps don't seperate the fuel from the electrical parts. As there is no air present .... no bang - gas / oil works as an insulator also. They are designed to run around 43psi or 3 bar. Obviously water is conductive which is not what you want inside the pump!
    Aquarium / pond submerged pumps will work although most feature a permanent magnet on their rotors which will pick up any iron or steel filings that get into the coolant so beware!
    Jun 2005
    45
    Thanks all for the replies, I will go with 1/4" as suggested.
    As for the auto fuel pump idea, they are also very low flow, so probably would not provide a lot of actual coolant flow at all, and they use a fair not of power to run. Best to go with an aquarium or pond pump as suggested, heaps cheaper too!
    Mar 2009
    296
    Quote Originally Posted by kawazuki View Post
    I didn't know that. That explains a lot. Do you also happen to know whats happening when a fuel pump is making a loud whine sound? Is it air bubbles caught in it?
    Feb 2008
    521
    Anyone's guess but air usually gurgles or makes pump 'rattle'. Whining is usually a sign the bearings are on the way out - could fail tomorrow or go on for years - and as most are non rebuildable you'll never really know!
    Sorry for the thread diversion!
    Mar 2009
    296
    Thanks Kawazuki.
  1. SPG 2217-20lv Milling/Drilling Machine (BF20)
    By fragger6662000 in forum Benchtop Machines
    Last Post: 01-02-2013, 12:00 PM
  2. BF20 Style cnc kit available
    By sgman in forum Benchtop Machines
    Last Post: 03-18-2009, 02:32 AM
  3. I need help to convert this BF20 Milling machine
    Last Post: 03-24-2008, 08:13 AM
  4. Converting a BF20
    Last Post: 03-17-2008, 05:12 PM
  5. Question about OPTI BF20 Vario
    By BMaynard in forum Benchtop Machines
    Last Post: 08-17-2006, 01:20 PM
