588,548 active members*
5,780 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 412 Axis Drive Not Enabling Heidenhain 151 controller
Results 1 to 9 of 9
    Sep 2005
    252
    Hi ,
    I turned this machine on this morning and smelled something funny now my controller comes on but as soon as i hit the power enable button to reference the limits it trips a breaker (C4) in the back cabinet and the drives do not get turned on.
    I changed the PSU , Changed all Axis drive cards including the power supply board. Checked the fuse in the control. I am not sure what to try next.
    Any help is greatly Appreciated
    Thank You
    Ray
    Oct 2010
    1189
    Re: Bridgeport Interact 412 Axis Drive Not Enabling Heidenhain 151 controller
    When you found the error and need Parts i might be able to help we retrofitted an Bridgeport 412 Complete we now have all electronics to sell just in case
    1121
    gotta check the wiring diagram and see everything that is connected to that breaker. If you have replaced everything then try replacing the breaker.
    Sep 2005
    252
    I found the problem last night it was the Benedikt & Jager Contactor that enables the drives.
    Dec 2012
    15
    I have exactly the same issue. Where was the contactor than enables the drives. Was is labeled? My machine doesn't have a contactor that looks like that?? Thank you. Tom Keyes
    Sep 2005
    252
    The Contactor is located in the back cabinet next to the circuit breakers ( to the right " ) it says " Benedikt & Jager K2-23A10 " on it.
    Here is where you can get a replacement.
    K2-23A10230 by IMO - Buy or Repair at PLCCenter - PLCCenter.com
    Good Luck
    Please let me know how you made out.
    Dec 2012
    15
    Thanks. I found it. Took it apart and found the housing had melted a little and was keeping it from engaging. I put it back in but still won't go.
    Thanks, I'll have to order one.
    Quote Originally Posted by RMARCH View Post
    Good Luck
    Dec 2012
    15
    Is there a way to mechanically actuate it for this weekend? I tried holding in the engaged position, but it didn't seem to affect anything. I assume these are just power activated switches? True?
    Dec 2012
    15
  1. bridgeport interact 300 with tnc 2500 heidenhain controller lost mp HELP!!
    By Dirt!croston in forum Bridgeport / Hardinge Mills
    Last Post: 07-04-2014, 12:19 AM
  2. Replies: 1
    Last Post: 02-11-2014, 06:23 AM
  3. Bridgeport Interact 412 Heidenhain 2500 control 4th Axis ?
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 01-05-2014, 05:16 PM
  4. Bridgeport s II interact II z-axis HEIDENHAIN
    By bigtoad170 in forum Bridgeport / Hardinge Mills
    Last Post: 05-19-2008, 01:15 AM
