588,653 active members*
6,568 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > CNC (Mill / Lathe) Control Software (NC) > 4-5 axis control recomendations for home built horizontal machine
    Oct 2004
    107
    Well I figured I would ask what some are using for thier 4-5 axis machines for controls. I am finishing up the design / plans for my home built horizontal machine.
    Just curious. I have selected most other items already. Havent spent any time on control choices.
    Oct 2004
    107
    No one? Well some specs at the least..
    -travels XYZAB 8X16X10 A ROTARY 380 degrees / B ROTARY continuous
    -Cast Iron base hardened machined and mating surfaces ground (3200 lbs) (old right angle from a crane).
    -356 Cast aluminum ways hardned and ground
    -Full enclosure with chip auger (part of small ice auger, with sheet metal shroud)
    -Plexi view windows.
    -Single 3 position tombstone with fixture plates ( for adding 5th axis, kurt 3600 vise or kurt modular vise systems.
    -Brushless 11000 mNm, 5400 rpm servos (24v) with built in encoders (0-5v).
    -Precise 10,000-40,000 spindle iso20 tool holders, hydralic drawbar (future addition of tool changer)
    -Precision ground 25mm High Pitch ball screws w/anti backlash nuts
    - NSK 28mm Liner rails and bearings
    -Way covers (Still figuring them out did not leave myself much room)
    Machine should be able to run 300-400 IPM rapids and 200-300 IPM cutting.
    Hopefully it will be solid enough to run a 3/8 endmill at 1/2 DOC and 100-150 ipm.
    24222
    Depends what you want to spend, two systems that will do all of that Camsoft/Galil & Acroloop/MotionMax.
    Al
    Albert E.
    Oct 2004
    107
    Well I have actually looked into camfsoft for a retrofit, and did not even think of it this time. I am not familiar with the acroloop / motionmax any more info?
  1. CNC Glossary
    By cncadmin in forum Community Club House
    Last Post: 03-09-2008, 09:08 PM
  2. 5 axis control system need suggestions
    By pab in forum Commercial CNC Wood Routers
    Last Post: 02-07-2005, 05:58 AM
  3. Need suggestions on components 5 axis control system?
    By pab in forum Mach Software (ArtSoft software)
    Last Post: 01-19-2005, 11:34 PM
  4. 5th even 6th axis? how does it work
    By ToMMY2ooo in forum Uncategorised MetalWorking Machines
    Last Post: 10-04-2004, 09:58 PM
  5. 2 axis linear machine control ?
    By vostryc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-06-2004, 01:30 AM
