Re: My 6040Z-S80 is acting weird!
Ok, is this a 6040 bought from Carving CNC or via Ebay?
If the latter, then you can safely assume the TB6560 driver box that came with it is the infamous bluebox controller rebranded to look like the one Carving CNC supply and is garbage. Throw it away, get a G540, and never look back.
If it's a Carving CNC, then start looking at all the wiring connections, swap the axis around to see if the fault follows one particular axis. Make sure you have ONLY a star style ground for everything, that is, one single point is where all the grounds run to.
Look at the cabling on the spindle, noise from this is a common problem, does this controller require a USB connection for the logic? Are you using a too long USB cable, or have you plugged it into a port that's not delivering the full 500mA? This is a common problem for USB breakout cables going to the front computer panel.
Basically if it's a genuine Carving CNC, then you have a noise or controller fault problem, if you have a rebranded bluebox sold as a Carving clone, then not working intermittently is how it works and it's performing as expected. Again, if so, throw it away and get a real controller!
cheers, Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
