Re: Wear offsets okuma multus b300
hy, i heared that some cnc's, other than okuma, allow more than 1 correction or wear / tool
i can program more than 1 wear for a single tool/offset, but it won't work easy and smooth like how it was there from the start
correction = offset + wear, thus, to use multiple wears you must use multiple corrections
pls check this :
![Quote](images/misc/quote_icon.png)
Originally Posted by
OkumaWiz
If you are only looking to update the tool offset, quit using the additional T01 command. You are telling the turret to index when you only need to update the offset using T21.
T010101 = RTO
T0101 = TO
T01 = O
RTO - radius + tool + offset, or radius + turret post + correction
thus :
T010101 ( correction 1 = offset 1 + wear 1 )
some code
T21 ( correction 21 = offset 21 + wear 21)
"offset 1" should be equal with "offset 21", thus there is required to measure the tool 2 times
you may avoid double measuring by using this code to autoupdate offsets : VTOFZ [ 21 ] = VTOFZ [ 1 ]
updating offsets may delete previous wear, so use it like this :
V1 = VTWOZ [ 21 ]
VTWOZ [ 21 ] = V1
you may also input one correction/wear from the interface, and another from code
how many corrections/wears do you need ?
