MODS I MADE TO THE COOLANT LINE ON MY PCNC 1100
Rory from Tormach posted a picture a few weeks ago of a modifacation he made to the coolant line on his PCNC 1100.
I have taken it a step or 2 further.
What I did was probably overkill because I used all brass pipe and real Loc-Line.
I moved the coolant line from the Z axiz to a fixed position on the column, then I used 1/4 inch brass pipe to build a manifold to get coolant to both sides of the part. So far, so good.
Then I put a short piece of 2 inch PVC pipe with a 90 drgree elbow over the coolant line. I did this mod because I use a fly cutter a lot, and when I do, it will splash coolant on the hose coming up from the tank. The splashed coolant then runs down to the top of the talk where there is no provision for any runoff so the coolant runoff eventually ends up on the floor creating a HUGE mess.
Since I added this pipe, I have had no more messes like that.
See what you have started, RORY?
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
