587,998 active members*
2,157 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Any way of scaling an NC drill file
    Sep 2005
    287
    This is not milling related but drilling.
    My circuit board is fractionally undersized. I'm guessing my printer which made my photo positive does not have super dimensional accuracy.
    Therefore I need to rescale my NC drill file very slightly to match the actual board size (hole centre distances). Unfortunately my cam software is not working in this respect and no matter how I attempt to change the scale on import, the hole to hole distances stay the same.
    My PCB software (Diptrace) does not have any scaling for exporting the drill file.
    Therefore I'm on the hunt for any way I can change the scale of my PCB drill file on export, or any software which can import and NC drill file, re-scale it, then export it again.
    Any ideas,
    Keith.
    Sep 2005
    287
    Re: Any way of scaling an NC drill file
    It's OK, figured it out. Export DXF from Diptrace then scaled in cad software. Got all hole locations perfect now.
  1. In Search Of a Simple Drill Bit Model file.
    By MetalShavings in forum Solidworks
    Last Post: 09-29-2014, 06:33 PM
  2. How to make a drill file?
    By TigerPilot in forum PCB milling
    Last Post: 10-31-2008, 04:34 AM
  3. NEW pcb drill hole file conversion TO G code
    By NASR1 in forum Mach Mill
    Last Post: 02-24-2008, 05:58 PM
  4. protel pcb Drill file problem with mach2 ?
    Last Post: 06-28-2007, 08:22 PM
  5. EaglePCB Drill file
    By TigerPilot in forum G-Code Programing
    Last Post: 04-27-2005, 11:39 PM
