588,464 active members*
6,555 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > What collet chuck is this
Results 1 to 6 of 6
    Jul 2008
    411
    As the title says, I have a collet chuck that came with the mill... but I have no idea what sort. Its on an MT3 taper. The chuck can handle anything up to 0.7" (17.7mm) through the nut and the internal opening for the collet in the main body is .88" (22.4mm) at the top. The nut is about a 1.25" (32mm) thread. The outer dimensions are 1.89" (48mm) dia and from the top of the nut to the gauge line is 2.6" (66mm). The nut has a steep taper, the chuck body a very shallow one.
    Ideas?
    Apr 2004
    353
    If you can post a picture of the collet, I'm sure it will be identified very quickly
    Mar 2005
    59
    Jul 2008
    411
    Thanks Juka, I'd seen that site before but it didnt help, none of the sizes seemed right...
    Here are some pics...
    Attached Thumbnails Attached Thumbnails collet1.jpg   collet2.jpg   collet3.jpg   collet4.jpg
    15362
    HI irving 2008
    Try Clarkson autolock the female part is clarkson but the nut does not look to be Clarkson but they may have made different types of nuts
    Try this one Clarkson Posilock Collet Chucks the Auto-Lock has a different Collet
    Mactec54
    Jul 2008
    411
    HI irving 2008
    Thanks, it is indeed a Posilock, knowing that helped me find out the other info I needed... including making the decision to go for MT3 collets rather than buy collets for this...
    Anyone want a Posilock chuck?
  1. Which collets to use with BT40 Collet Chuck
    By JMFabrications in forum MetalWork Discussion
    Last Post: 05-19-2009, 02:21 AM
  2. A sprung loaded collet chuck
    By JaguarB in forum Engraving Machines
    Last Post: 12-12-2008, 09:21 PM
  3. collet chuck onto rotary table
    By ptxman in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-15-2008, 06:35 PM
  4. Air collet chuck for a c3?
    By gazmalman in forum Mini Lathe
    Last Post: 06-16-2008, 12:23 AM
  5. Which collet chuck?
    By Al_The_Man in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2004, 07:11 AM
