Optical fiber laser marking machine is now divided into domestic laser marking machine and the price of imported laser marking machine, two kinds of domestic and imported prices are different, the domestic optical fiber laser marking machine price is much cheaper than that of imports, but at present domestic fiber laser is not very stable, but the fiber laser marking machine marking features are the same, the introduction of the characteristics of optical fiber laser marking machine, can be in the vast majority of metal or nonmetal materials for processing.Nonmetallic material hardness higher to marking, fiber laser marking machine is a non-contact processing, do not produce mechanical extrusion or mechanical stress on the material, need not consumable materials, non-toxic, rarely cause environmental pollution,the laser marking machine price is reasonable.
Optical fiber laser marking machine laser beam is very fine, cause the materials consumption is very small.Processing, not like processing methods, such as electron beam bombardment produces x-rays, also won't be affected by the interference of electric and magnetic fields.But because of the influence of magnetic field, optical fiber laser marking machine operation is simple, using computer numerical control technology to achieve automatic processing, can be used for production line of spare parts for high speed high efficiency machining optical fiber laser marking machine using small precision worktable can be fine processing.Optical fiber laser marking function of bar code, number, character, pattern, etc.
Laser marking machine with double solution
Users may have laser marking machine in a mark ghosting phenomenon appeared.In other words the laser marking machine at last points out the conditions of light will find in a light point distribution around a few weak points, tell you solve below laser marking machine with double solution
The first, because different manufacturers set up different, you can try several time delay parameters
The second, it is possible that the noise caused by the pulse signal, if not the above reasons, is caused by laser transverse mode is not good.Treats the symptoms, you can add holes inside the cavity, or increase the hole after beam expander, root words will change the design of the laser cavity.
The third, it is possible that some reflection in optical path components of emission rate is not high, such as 45 degrees of reflection in the mirror of the 0 degrees) caused by the former behind twice reflex, the solution is to run bar filter, the several small point can filter out and change the relevant delay parameters, usually is caused by the galvanometer delay time is not enough.To check that the light, the light side if no problem, looking at the control section, this mainly a virus is a computer system, the parameters are right, as well as vibrating mirror.
Have adjusted the fourth, first take a look at the light class, look at the switch laser delay is not good.Then see various optical lens,the prospect of laser marking machine for sale is very good.
Attachment 238850Attachment 238850
