I took delivery of a new g0704 mill a few weeks ago and have been in the EXPENSIVE process of gathering tooling and measuring equipment. Ultimately i hope to build a little live steam train 3/4" (i also got a g0602 lathe).
I am having some issues with the mill - specifically with the TTS tools pulling out of the spindle (Tormach). I think this is because i am not able to tighten the collet enough. That might be due to a missing or incorrect spindle ring. See attached picture. It is not a complete ring - is that correct? Should there be grease this high. When tightening the drawbar with the two wrench method the spindle still turns despite holding the low wrench. More effective is holding the spindle nose by hand though i am sure this is not a the preferred method.
I have seen some threads about pneumatic powered draw bars. I am interested - because soon i will have that three hand problem common with TTS. That said - before i deal with air compressors and cylinders. If i install the belleville springs (i am assuming these would be installed between the drawbar and the spindle (see second picture). Would i be able to fabricate a lever that i could operate by hand? Not being an engineer - any idea how long that would have to be to apply enough force? Would i have to make or buy a longer drawbar? How many washers (looks like i would have to have an even number so that the upper and lower washers have a surface to bear against.
Thanks in advance for the help - there is so much to learn and i am brand new to this!!!
Of course - if i can get this to work manually eventually pneumatic operation will follow.
hoping to do a CNC conversion in the future as well - though that might be tough without a second mill... unless i get one of those kits i read a number of people have under development...
