Originally Posted by
A_Camera
Thank you for the kind comments.
Sorry that you have trouble, but in that case I think you made a mistake in the editing process and did not follow my instructions by the letter. I found that the best and safest workflow is to open the used screen set file, for example the Defaultscreen.ssf, find the region for your controller, create a separate file for the specific controller and make all the editing in that file. That way each string you search for will only be found in that part. It is very critical that changes are ONLY made in the relevant part of the ssf file. Once the editing is done the whole edited file can be copied and pasted into the used ssf file, replacing the one delivered by CNC Drive.
Beware that there are several UC300 USB controllers, so it is very important that you work with the one you have. I edited my ssf file for the UC300_5LPT on two computers, one which was the one where I wrote the instructions, the other was the one I use for controlling my CNC. On both of them, the screen shows up and the macros are called, so my instructions are definitely well tested.
Anyway, I include the UC300_5LPT file here, this is working on my computers, even if only in demo mode because I don't have a license for this controller. if you want to test it just paste it in place of the one delivered with UCCNC. I have never used or tested on 1.2036, or any other than the 1.2037 version of UCCNC, and I don't know if the user fields are working on any other version than 1.2037 but the screen should definitely show up. If the user fields are not supported in earlier versions then you need to edit each macro and change accordingly.
