Would just doing a section view at each needed location be enough? You can put dimensions into the sketch while making the section view sketch. Then you can usually dimension the section view. Some 'laminar' edges might not want to take a dim but for the most part it will work. It will depend greatly on the shape and type of model [lofted vs extruded etc].
The other way to do it.. is to do section cut's as a 'configuration' then you'd make a drawing for each configuration. This second way works great, but is a bit more work.
If you want I can post samples.
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
