588,671 active members*
6,065 visitors online*
    Jul 2003
    126
    Rattle up top
    Bridgeport clone (Hartford) step pulley 9x42 mill.
    During heavy cuts I get a rattle up top. Sounds just like it if from the main pulley on top of spindle.
    Tonight I took pulley system off, nothing noticable. Only thing I think it may be is the H/L engangement thing (not sure real name). Reminds me of a detroit locker in a car or something.
    Anybody else have this issue, is it normal, what do I need to fix?
    Jeff
    927
    Ty,
    That is hard to say from here.
    Could be the bull gear assembly or the motor or the motor shaft / pulley.
    Does it happen in both high and low?
    If only low, I would look at the bull gear set.
    Both high and low, I would look at the pulley to motor shaft interface or the spindle.
    Here is a link to replacement parts.
    http://www.hqtinc.com/catalog.cfm
    Sorry, not much help from 1000 miles away. Sometimes you just need to be there.
    Jul 2003
    126
    Yes, happens in both speeds.
    I am 99.9% sure is nothing to do with the motor or pulley that is on the motor.
    Nov 2004
    3028
    When you took the varidrive apart how much play was there between the bushings and the shafts? Are the keys worn? How much play in the clutches? (But this only relates to high gear.)
    George W.
    4826
    Is there a spline drive inside this spindle? Perhaps the spline is getting worn.
    You might try replacing the belt. A lack of horsepower could also contribute, depending on how heavy your heavy cuts are. If the cutter tends to slow the spindle with every tooth engagement, it could cause a rattling effect.
  1. Top Tech CNC Milling Machine from penn tool
    By wisp in forum Knee Vertical Mills
    Last Post: 03-29-2011, 12:43 AM
  2. Fadal is back on top!!! NOW WITH PICS!!
    By carbidecraters in forum Fadal
    Last Post: 04-08-2006, 02:52 AM
  3. Carved Guitarbody Top
    By magicaldog in forum Rhino 3D
    Last Post: 02-24-2005, 10:01 AM
  4. Top Ten Signs
    By wms in forum Community Club House
    Last Post: 06-22-2003, 01:04 AM
