588,344 active members*
5,224 visitors online*
    Nov 2007
    4
    Taper correction help
    First post so I am not sure I have it in the correct place
    Have a Hawk 250 with the Vickers controller and Acramatic 2100E. Problem is I have .001 taper in a 1" travel in the Z axis, how do I correct the machine to have 0 taper in Z travel.
    Read the books and still can't seem to find the answer, please resond in slow simple terms as I am new to the CNC scene.
    Thumper
    2010
    Read thru my conversion of a Grizzly lathe. I had this problem and there was quite an exchange of ways to correct it.
    http://cnczone.com/forums/showthread.php?t=26530
  1. What's the taper on this?
    By la_coterie in forum Commercial CNC Wood Routers
    Last Post: 02-20-2010, 09:15 PM
  2. NOTES ON BACKLASH CORRECTION IN Mach3 1.90.004
    By chris59 in forum Machines running Mach Software
    Last Post: 05-09-2007, 06:00 PM
  3. Taper 40 N.S.
    By professor in forum Charter Oak Automation Support Forum
    Last Post: 01-14-2007, 02:14 AM
  4. BT to CAT Taper
    By machinistJ in forum Fadal
    Last Post: 02-14-2006, 09:36 PM
  5. R8 taper
    By lt paul in forum Uncategorised MetalWorking Machines
    Last Post: 06-10-2004, 04:31 PM
