587,238 active members*
3,661 visitors online*
    Feb 2013
    26
    Milling a 235" part thats 16" wide
    Ok i need some help im looking for a mill that has the capacity to hold a 235" long part and is 16" wide we machine them all the time and we are using an old manual machine that was retro fitted with a cnc control. Problem is the machine is so old that you can no longer buy anything for it. And it is wore out. We machine these parts everyday so we have to replace it. I can not seem to find anything with this capacity. Any Advice?
    May 2005
    3920
    Quote Originally Posted by heavenlykid View Post
    You likely need to look for a planner mill. Sometimes these are called gantry mills. Try these guys for a new machine: GantryBridgeMill. This isn't a cheap buy though, as such you need to look at the used market and customization of an existing machine.
    You don't describe the part nor volumes nor machining requirements. However it might be sensible to do a full custom machine.
    Dec 2006
    39
    Elumatec and Emmegi make machines that can easily take this. They are also 5 axis.
    Hi sir.....how are u
  1. milling a "lathe part"
    By pejaer in forum SprutCAM
    Last Post: 06-18-2012, 09:42 PM
  2. Timing belts are 3/4" wide and only come in 3/8" wide?
    By CATCH22 in forum Uncategorised MetalWorking Machines
    Last Post: 01-27-2012, 08:44 PM
  3. Machining 1" wide x 2-1/4" deep slot
    By midguard in forum Uncategorised MetalWorking Machines
    Last Post: 02-16-2011, 12:15 AM
  4. Replies: 6
    Last Post: 06-24-2008, 01:14 AM
  5. Clearing out ½" deep 1" wide in Acrylic
    By carguy327 in forum Glass, Plastic and Stone
    Last Post: 10-04-2007, 07:32 PM
