587,103 active members*
4,094 visitors online*
Results 1 to 1 of 1
    Just built this 6x6 framed router
    I just spent the last two weeks putting this together. Framing is 6' x6', made out of 3" 3/16(7ga.) tubing. The two Y axis ballscrews are 16mm. The X axis is a 25mm ballscrew. Z axis is a 16mm ball screw. Both Y axis and X axis are driven with Nema23 570oz. motors. And the Z axis is a Nema34 1200oz. motor. I made all of the mounts to be adjustable, in case I needed to later go to larger size motors. But there doesn't appear to be a problem with the Nema23 motors for X/Y.
    I'm using Mach3 with a C10 BoB, and an Ethernet smooth Stepper card. I use Fusion360 for CAD/CAM.
  1. Painting a metal framed CNC Router
    By Sterob in forum DIY CNC Router Table Machines
    Last Post: 07-25-2021, 02:25 PM
  2. ScratchPad - DIY Steel Framed 3x3 Router
    By amishx64 in forum CNC Wood Router Project Log
    Last Post: 01-03-2013, 03:47 AM
  3. 6x6 cnc router
    By money1 in forum DIY CNC Router Table Machines
    Last Post: 01-16-2010, 06:14 AM
  4. long term stability of wood framed router
    By dave925 in forum DIY CNC Router Table Machines
    Last Post: 05-06-2005, 05:33 AM
  5. 6x6 Router?
    By Cold Fusion in forum DIY CNC Router Table Machines
    Last Post: 02-02-2004, 06:57 PM
