588,613 active members*
6,165 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Re-establishing CS position?
    Jul 2009
    9
    Currently working on a 1987 Fadal VMC40 ("2216") with a CNC88 control. I'm used to working on a late 90's 3016L with the 88HS.
    On this VMC40, there's a Cold Start location tag on the X-axis, but I'll be damned if I can see one on Y and Z. There's what looks like a hand-made mark for Y-axis location but I'm wary of it.
    Is there a way of re-establishing where the cold start position should be? I had been playing with different Z.0 positions to get the TC to work.. and it seemed no matter where I told the machine "0" was, I'd always have +4" of Z travel. Like it was hitting a software limit, rather than a physical limit switch.
    Thanks!
    cs marker
    You are right about the software limit. There are no limit switches on Fadals.
    This is how to set the cs on Z
    - bring z close to atc zero
    - put a tool in and activate m19 orientation
    -hit the jog button
    -manually swing the atc to the extend position and see if the tool and atc turret line up
    - if not, jog z up or down until atc lines up
    - scribe or mark a line
    -hit jog again to send atc home
    - hit cs now- if Z jumps off your mark, you have to turn the resolver in the servo
    for Y
    -cs mark is in th center of the travel
    Jan 2004
    3154
    Good to see you are still around Jamie.
    When you going to be back in my area?
    www.integratedmechanical.ca
  1. re establishing arc
    By bvweld in forum DynaTorch
    Last Post: 09-24-2008, 06:08 AM
  2. Looking for programming position O.C. ca
    By jellis1 in forum Mentors & Apprentice Locator
    Last Post: 05-16-2008, 08:35 AM
  3. Looking for position in CO
    By petriej in forum Employment Opportunity
    Last Post: 01-23-2008, 02:40 PM
  4. lost z position
    By positiverake in forum Daewoo/Doosan
    Last Post: 11-28-2006, 03:06 PM
  5. From/To car position
    By John F in forum OneCNC
    Last Post: 08-28-2003, 02:45 PM
