Has anyone tried using the tool comp in mach 3;
I use it in mach 2 and I can see in the toolpath display where the tool comp'ed path is different than the non-comp'ed path (a profile cut around my part, done once without comp then again with)
But in mach 3 it showes the same path with and without tool comp.
Maybe my lead-in moves are incorrect.
Also, does moving the Z axis alone (without X & Y) turn tool comp OFF?
Dennis
