588,205 active members*
4,002 visitors online*
    Jun 2006
    424
    G-code manual for Mach3 turn?
    I could really use a manual with a brief explanation of code lines used in Mach3 turn.
    I have some experience working with other controls, but some of the codes that I used do not apply to Mach3's control, and others substitute for them, but I don't know how to use them as they are not adequately covered in Mach3 turn documentation.
    Things like peck drilling, and automatic roughing finishing cycles would be great to understand how to execute in Mach3.
    If you know of anything, like a cliff-notes G-code HAHA let me know.
    Jun 2006
    424
    The manual doesn't adequately cover a lot of functions.
    The peck drilling cycle has no example, for instance. A lot of the information in the manual is good information, but it seems to me to be partially there.
    for me it's the difference between manually programming a peck drilling cycle, and program a one-line solution to my problems. I prefer the one line solution. One program I just wrote was a 5.5" deep hole in .2" pecks- like 125 lines of code.
    The drilling cycle I was familiar with is not compatible with Mach turn- They are using a different cycle.
    Jul 2004
    442
    G83- Peck with full retract
    Z final depth
    F feed
    Q depth of each peck
    R Location of retract
    Make sure x is zero
    The cycle will start from the present position
    Jerry
    Jun 2006
    424
    Thanks for the tip.
    (so assuming retract is z0, would that look like r0.0 or rz0.0?
    Is their a resource somewhere online where I could print additional information such as that?
  1. I NEED: DX-32 manual, 1104-2832 VMC Operator's Manual, DX-32 CNC Control
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 05-31-2012, 02:21 AM
  2. New FeatureCam Mill (3axis) and Turn Posts for Mach3
    By chris59 in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-05-2008, 08:43 AM
  3. mill/turn on a cin turn
    By Robert Timby in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2007, 05:33 AM
  4. Cin Turn turn/mill
    By Robert Timby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2007, 02:12 AM
