Okay, Let me see if i have this right. Havent purchased the software/controller yet, but will be in the next week or so.
Limit switches are all n/c and are all wired together in series, One side of the circuit goes to the limit terminal, where does the other side go? Ground or +5V?
Same for the E-stop switch, ill assume this should be a n/c and hooked up like the limit switches?
Should the E-stop switch send a signal to the software AND shut power off at the stepper power supply?
Home switches should be n/c circuits, Should they end at ground, or +5V?
Does the controller need +5V coming from the computer, or does it share the +5V with the Geckos?
What about Pause and Start switches?
Thanks for any help,
Dylan
