587,787 active members*
3,094 visitors online*
Results 1 to 9 of 9
    Dec 2008
    17
    amada pulsar 2415 cut conditions
    We recently acquired an amada 2415. It cut really well until several changes were made to the cut conditions. Does any one have some type of cut condition reference list for this machine? I need some starting points for feed rates, wattage, frequency, duty and etc. Anything would be appreciated and better than what I have now.
    apexengineering
    Mar 2010
    we have a 2415, i could help you out with a few, although I'd have to write them all down manually, so let me know which ones you need specifically and I'll sort those out for you. In the back of the user manual there is a base setting chart too, btw.
    Dec 2008
    17
    2415 cut conditions
    Bryden,
    First of all thanks for your repy. I would like cutting conditions for the following:
    18 ga. (.048) crs
    16 ga. (.059) crs
    14 ga. (.074) crs
    16 ga. (.060) stainless steel
    14 ga. (.075) stainless steel
    I have looked at the back of the book and to me it looks like all of the default settings start out at maximum wattage, duty, etc.
    sent you a pm
    apexengineering
    May 2006
    94
    What is the wattage of your laser? I've just picked up an Amada 655 1500w, and there are several sample pieces that came with it. should be good for a start. I'll get back with those once I get into the shop.
    Dec 2008
    17
    amada pulsar
    the amada pulsar 2415 is a 2500 watt
    apexengineering
    May 2006
    94
    These are off of small notes on sample pieces. Should be self explanatory, but I'm not going to translate. (I'm going to assume metric settings
    0.250" steel(crs?)
    S=1500w
    t=30hz
    b=20%
    f=200
    o2=5kgf/cm2
    0.0625" SS
    S=1500w
    t=2000hz
    b=35%
    f=1200
    N2=8kgf/cm2
    0.0625" MS
    s=1500w
    t=2000hz
    f=2500
    b=30%
    PA=673w
    o2=0.25
    0.235" ms
    s=1500w
    f=1100mm/min
    t=2000hz
    b=40%
    o2=0.75kgf/cm2
    0.055" ms
    s=1500w
    f=400mm/min
    t=400hz
    b=20%
    o2=1.8kgf/cm2
    I apologize if anything sounds cryptic, but that's what I have to go with right now. Once the power company gets me 3-phase power, I'll have more info from the Amada people during installation.
    Jul 2010
    how to take the deburr of a hole... i know it has a starting point and end point but it leaving me a burr specially on really thick material...anyone can help?!!!!! i have a really close tolerance...
    Jul 2010
    Angry HELP!!! HOW TO TAKE THE BURR OFF ON A LASER CUTTING HOLE!!!!
    I NEED HELP FINDING A WAY TO TAKE THE BURR OFF ON A LASER CUTTING HOLE... I KNOW IT HAS A STARTING AND ENDING POINT.. EXAMPLE WHEN I CHECK WITH CALIPERS HOLE CHECKS .125 BUT WITH GAUGES IS UNDER SIZE BECAUSE OF THE BURR THE LASER LEAVES.... ANYONE CAN HELP ME!?
    May 2006
    94
    I'm making the assumption that the burr you are referring to, is on the side of the cut, and not the dross below the cut.
    The size of that burr, is just a factor of your cut conditions. If you need a perfectly smooth hole, then you are not going to get that with a laser.
    Pulse freq, pulse duration, speed, assist gas, focus, and power all have an effect on that burr. When conditions are the best they can be, that burr will be minimal, but still present.
  1. T1 101 missing conditions
    By nastek in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-10-2010, 07:23 AM
  2. has anyone set up cutting conditions
    By laserkey in forum Tutorials
    Last Post: 04-05-2009, 11:01 PM
  3. Amada LC644/667II cutting conditions help!!!
    By Marian1972 in forum Fanuc
    Last Post: 11-24-2008, 10:39 PM
  4. Working conditions
    By Geof in forum Safety Zone
    Last Post: 12-22-2005, 05:57 PM
