Hi All,
Can anyone tell me how to set the resolver position correctly---relative to the rotor on a control techniques Ac servo motor.
Hope someone can help
thanks in advance
Bert
Hi All,
thanks in advance
Bert
Hi Bert what motor do you have is it a Uni-motor UM or Duty Max DS also is the drive a Control Techniques drive if so what type Max, Uni-drive classic or Uni-drive sp if the latter two then these can be used to do the alignment.If you drop me a line with the details I could give you an alignment procedure for the motor
