588,571 active members*
6,605 visitors online*
    Aug 2005
    13
    Brother TC-215 CRT problems
    On my brother tapping center the CRT screen is broken. So now I put an external TV on it and it works fine. But is want to put a screen back into the machine. I bought a TFT monitor and installed into the machine. But than the problem begins. The TFT display is working but the image is not steady. I think it has some problems with the frequentie.
    Do some body know if i can make a convertor or a way to make the image steady. It's like it missing some frames per second.
    24221
    Was the monitor you replaced it with a analogue VGA or TTL? if so what resolution?
    I assume you have fitted a TFT monitor with built in display controller , does it have 15pin vga or 9 pin connector?
    Some of the older CRT displays were low freq EGA.
    Al.
    Albert E.
    Mar 2005
    171
    Do you upload and download programs from your Brother CNC to a computer?
    If so, what cabling and software are you using?
    Ben
