588,202 active members*
3,939 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Need tool and start advise.
    May 2013
    17
    I have my CNC MOGUL ROUTER coming in Monday, JULY 29TH and I would like to know the basic bits needed for 3D routing and what software to use as a starter. My machine is coming with Mach3 stuff and I am at a loss on how to get started. I do plan on using some ready to cut designs from Vector.com to practice on but I would like to scan in my own artwork from then on.
    Any advise on how to do this?
    Apr 2004
    5757
    The basic bits used for 3D carving are ball-nose endmills. You need to use them because ordinary flat endmills won't make contoured surfaces due to their geometry. If you're starting out with pre-modeled 3D reliefs, try DeskProto to convert them into G-code your router will be able to run. If you want to make your own 3D models, the choice of CAD software really depends on the sort of things you want to make, as well as issues like your budget and tolerance for learning curves.
    You mention scanning in your own artwork. Does this mean you plan to get a 3D scanner to scan sculptural work? Or do you plan to do 2d routing, use 2D scans as a basis for 3D CAD models, or convert gray-scale images to 3D?
    Andrew Werby
    www.computersculpture.com
    May 2013
    17
    I had heard if you scan artwork in as grayscale, one can convert them to 3D vector models. Dunno, I am very green at this. Seems like there should be a 3D vector book for dummies some where.
    The very elementary instructions on what to do 1,2,3. or a,b,c. :-|
    What shape and size bits should I buy?
  1. Engraving Tool Advise
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 03-29-2022, 12:56 AM
  2. Spindle start and stop and tool change
    By inman20k in forum BobCad-Cam
    Last Post: 09-15-2012, 10:35 PM
  3. Replies: 1
    Last Post: 07-01-2010, 03:05 PM
  4. Tool Start position
    By Mike.C in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-17-2008, 03:20 PM
  5. Tool presetter advise.
    By glovebox20 in forum Calibration / Measurement
    Last Post: 08-10-2007, 11:37 PM
