588,265 active members*
7,122 visitors online*
    Sep 2004
    40
    Auto bar feeder
    Has anyone been able to come up with a safe and reliable bar feeder for the CNC conversions. I looked at the one Haas has for the SL10 series and it doesn't appear to be more than a piece of pipe with a pnuematic ram and something to measure the distance it moved. Seems like it wouldn't be hard to copy that for the DIY crowd. At $2995.00 that seems a little steep to me for what it is.
    Jul 2005
    12177
    Have you done a search on cnczone using 'bar feed'? You might find something.
    Mar 2007
    463
    Before we purchased our first bar feeder ( $30,000 ) we used a spring collet mounted in one of the tool positions on our CNC. We made one holder with changeable jaws to fit tight on the stock we were using. Then you just stop the chuck, align the collet to X0, force it onto the stock, open the chuck and pull the stock out to where you need it, then close the chuck and pull the collet off the stock. Cost is SMALL when you compare it to buying a bar feeder. Just remember that the collet needs to be just tight enough to pull the stock, not so tight that it pushes the stock back in the chuck before you open it.
    Larry
    Nov 2006
    925
    Larry,I used to do the same,only I used a feed finger from an auto instead of a collet.As I have thousands of feed fingers I made an adapter for the turret to screw them into.
    Mark.
  1. Servo 300 Bar Feeder
    By wudbutcher in forum Haas Lathes
    Last Post: 08-24-2010, 04:17 PM
  2. DIY hydro bar feeder ?
    By D.D.Machine in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2009, 03:58 PM
  3. MTA 541 Bar feeder
    By DocHod in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-03-2007, 04:03 AM
  4. auto feeder
    By Syphonics in forum Mechanical Calculations/Engineering Design
    Last Post: 12-20-2006, 04:14 PM
  5. Simple Bar Feeder
    By Jarwalcot in forum Uncategorised MetalWorking Machines
    Last Post: 02-24-2006, 08:10 PM
