588,322 active members*
4,892 visitors online*
Page 1 of 2 12
Results 1 to 20 of 27
    Aug 2006
    12
    VF2SS shutting down
    I purchased a used 2005 (aprox 9 months old) VF2SS 1 year ago and have been machining the same part since then.
    My problem is that during a tool change the machine goes into alarm and stops.
    The alarm messages are
    102 Servos off
    123 Spindle drive fault
    105 Z servo error to large.
    I've had the local Haas techs out to try to fix it many times. They have added 2 more fans under the controller cards as well as replacing the card itself. The Z drive bearings have also been replaced. After all this the problem is still there.
    In the hot weather it shuts down more than in the cold weather. I've had it go down 11 times in a 14 hr day. On average it's 3-4 times per day which is a LOT of down time!! and that is with the electrical cabinet door open and a big fan blowing lots of air inside the cabinet (as per the tech's suggestion). During the winter I can go for days and sometimes weeks without any alarms.
    The local tech told me that the program I'm running had too many tool changes for the cycle time. 10 tool changes in aprox 8 minutes.
    I have checked with another company locally that has a VF2SS and from what I understood they are running a similar cycle and number of tool changes.
    The last time the tech was over I was told they can't do anything more for me. Pretty sad really.
    So my question is ....has anyone else experienced this issue on a VF2SS or am I the only lucky one.
    FYI the times between tool changes and RPM's are
    Tool 1 19 sec 10,000 rpm
    Tool 2 125 sec 10,000 rpm
    Tool 3 18 sec 10,000 rpm
    Tool 4 37 sec 10,500 rpm
    Tool 5 42 sec 9,500 rpm
    Tool 6 146 sec 10,000 rpm
    Tool 7 50 sec 10,000 rpm
    Tool 8 10 sec 5,500 rpm
    Tool 9 10 sec 700 rpm
    Tool 10 11 sec 5,500 rpm
    Any comments would be greatly appreciated.
    Mar 2004
    564
    Hi, I've never worked on a Hass, but I have plenty experience repairing other cnc's so here is a list of things to consider..
    "Z servo error too large" sounds like a following error to me.
    So What came first the drive fault (spindle faulting) or Z axis not in the right position during a tool change...
    1. due to z axis brake failure if your machine has a brake on Z??
    2. Backlash on Z axis ball screw/assembly
    3. spindle drive faulting ? too much amps, drive hot, loose wiring
    4. spindle not orientating to correct position to accept a tool change,not sure what type of tool holder you use?
    The drive for the spindle might want to see the spindle ramp down to a certain speed before allowing a tool change to occur? try and slow the machine down as a test to see if your problem lessen's (spel?)
    maybe in the G-code before the tool change is called out, call out a wait,or dwell for a certain amount of time and then do a tool change, play with the time value and see if it helps.
    Record the Z axis position during a fault and compare it with where it should be during a tool change, moniter the amps on both the spindle drive and z axis when running good and try to capture it when it faults to see if you are drawing too much amps, that might indicate a tight spindle or a damaged ball screw/assembly....I could go on, but it's hard to be an arm chair mechanic.
    If the Haas guys have given up, I'd look at your g-code and see if maybe you need to tweek it a little, as your machine gets older, the optimized time you once had might be slipping away due to wear and tear.just like an old car needs a little more TLC??
    My 2 cents
    hope it helps.
    menomana
    Aug 2006
    12
    Hi trubleshtr, thanks for the reply. I'll take a look at some of your suggestions and go from there.
    Jul 2005
    12177
    It sounds like it is an overheating problem. Here are some possible ways to combat it.
    Reduce the spindle acceleration maximum load. The factory setting is 195% for Parameter 196 Sp ACCEL LIMIT LOAD. Change the 195 to something like 120, the accelerationg time does not change noticeably.
    Separate the rapid return to Z zero for the tool change from the spindle stopping and orienting. On the Haas the normal tool change command is just Tn M06 and the controller homes Z, stops and orients the spindle all at the same time. Put G53 G49 G00 Z0.0 on the line ahead of the Tn M06 and the Z axis will home before the spindle orients which puts less demand on the DC power supply.
    Jul 2007
    52
    We have a VF2SS of similar vintage and very similar tool cycle times. Our factory varies from about 5°C in winter to 37°C in summer. We had the Z axis servo amp replaced about 12mths ago. Other than that it runs 16hr shifts every Monday to Friday and has done over 630,000 tool changes with out a stop. The HFO we deal with are very prompt and if they can't solve it they call the factory and have an answer back the next day.
    Andrew.
    Apr 2007
    178
    what voltage are you bringing to the machine is it 208 240 or 480 is it a delta or wye wired configuration? the z axis fault is a by product of the 123 alarm the 123 alarm is a spindle drive fault when this happens the z axis overload because the spindle is not turning anymore. are youi able to reset the 123 alarm or do you have to power down the machine?
    Apr 2007
    178
    are the regens smoking hot when you run the job?
    there was a vintage of vector drives that had 123 alarms because they sensed ground faults in the power line usually this only happens on ungrounded systems like delta which is usually 240 volts with no ground reference. the haas machines are not meant to be run on ungrounded supplies and i do not think there are many companies out there that will ground a delta system. sometimes the vector drive interprets a phase imbalance as a ground fault and it may be. there may be a machine in your shop that throws what looks to be a ground fault on a delta circuit since the voltage does not have a ground reference the stray voltage just bounces around the 3 phase circuit. if you are able to reset the alarm right away and continue then this may be your problem if not and you are just running the machine too hard you can put a couple of dwells in the program to see if that helps or you can slow the accel decels on the spindle down to ease up on the vector drive or regen assemblies.
    Feb 2007
    205
    check to see you have the right regen. There should be 4 elements in the regen box on top of the control cabinet. You could have a bad regen. Have the tech check the ohm's on the regen, it should be 5.6 ohm.
    Jul 2007
    195
    If all else fails try a cold air gun. You will have to mount it outside the box because they drip water from condensation. Just pop a hole thru the box and point the gun thru the hole. you could set it up with a timer to turn it on and off thruout the day. A cold air gun will turn regular shop air into 38 deg air.
    I have used them before to cool controls
    Be carefull what you wish for, you might get it.
    Jun 2007
    35
    When does it fault out during the tool change? When its removing the tool or placing the tool into the spindle?
    thanks
    Mar 2004
    564
    Serviceman has a good point.... Check the regen circuit, the poor machine might not be able to dissapait (sp?) excessive power in the system when you ask it to quickley stop....Deffinetly check the Ohms values on the regen circuit....
    menomana
    Aug 2006
    12
    Hi all, thanks for the responses. I'm gonna try and answer them as best I can.
    Geof...I've always thought it was an over heating problem too so when I get a chance I'll try your suggestion.
    omy005 (Andrew)..Glad to hear that someone has a machine that doesn't have this problem. Your temps are a bit higher than what we experience during the day so I wonder whats different with your machine???.
    Serviceman...Voltage to the machine is 208. I don't know if it's delta or wye wired config. Sorry but electrical is not one of my strengths.
    You said ......."the z axis fault is a by product of the 123 alarm the 123 alarm is a spindle drive fault when this happens the z axis overload because the spindle is not turning anymore".
    Well when the machine goes into alarm, the spindle is still rotating so I have to wait until it comes to a complete stop (aprox 6 mins) then clear the alarms. When I clear the 102 alarm there is a "clunk" and the spindle is locked .Next I have to do a recover in order to start running the machine again.
    No I don't have to power down the machine and the regens are not "smoking hot" when the machine is running. The top 2 elements are hotter than the bottom 2. I've even put a fan in front of them to help with cooling it didn't help. Another thing the vector drive has already been replaced and yep it did nothing.
    The only other machine in my shop is a compresor.
    HAILINHAAS.....thanks for your suggestion I'll get a tech to check the ohms, and as mentioned above its a 4 element regen.
    JROM....will leave that as a last resort. If others aren't having the same issue then there is something wrong with this machine.
    HaasTech83..... The machine faults with a tool in the spindle the next tool facing down in the side mount tool changer. The tool changer arm is in it's 'home' position ready to turn and grab both tools to do the change.
    Hope someone can make sense of all this. Thanks again for everyones input. Greatly appreciated.
    Fantail
    Jun 2007
    35
    I'm thinking the z servo alarm may be caused by the 123 alarm. The 123 shuts the servos off and the head drops slightly, due to the time it takes to engage the brake. This could cause the control to believe that it was forced to move there.
    The spindle should orientate and stop, but your not getting any encoder related alarms so i don't believe that is your issue, it still could be. Have you monitored the incoming voltage on your warm days, does it change any?
    If your overheating your regen, you should get a regen overheat alarm.
    Do you get this 123 alarm during normal milling ie not during a tool change?
    thanks
    Mar 2004
    564
    We installed filters on all our machines, the electricity in our area is "dirty" and on a hot day when everyone/thing is demanding power from the grid we use to see wild fluctuations in the incoming power.Lights flickering,machines shuting down ect...
    we now moniter 3 phase in the machines (line voltage monitor) and have paid a 3rd party to install "filter's" to save enegy and better condition the power in the machines.
    We also improved our grounding circuit.
    Later we had hydro come in and upgrade our building's external transformer to the factory...more power....
    hope this helps.
    I guess what i am trying to say is maybe your electricty is bouncing and your drive/controls are shuting down as a possability.
    menomana
    Aug 2006
    12
    Geof, went to change parameter 196 today and go the message....function is locked...how do I unlock it? so I can do as you suggested.
    Fantail
    Aug 2006
    12
    Hailinhaas....got an electrician in to check incoming power & the regen. Hmmm he forgot to turn the machine off and tried taking the regen unit part. He quickly stopped when an element shorted out and gave him a big tingle. Needless to say I had to replace the regen. The new one checked out ok at 5.6 ohms. So eliminated that from the list.
    Feb 2007
    205
    Spindle Z fault could be a bad encoder on the spindle .. check to see if the assembly is tight and the belt is not loose .. The low volt power supply board could be your problem if the machine shuts down .. there is a sensor that could be turning your machine off .. what does the machine do before it shuts down on you .. is there a warning?
    Feb 2007
    205
    Sorry .. my bad .. I said Spindle Z fault .. you have a drive fault .. that leads to the vector drive ... might need to replace it ..
    Feb 2007
    205
    Wink
    I read your original thread .. I see you already replaced the vector drive ..hmm .. You should have a 45 amp servo amplifier in the control cabinet for the Z-axis ... I suspect that one of the amplifiers are bad and could be drawing power from the vector causing it to give you the drive fault .. or the motor on the Side mount tool changer is bad .. when does it actually alarm out .. is the z-axis in position to do the tool change ... or is it when the spindle is coming to a stop? Does it only happen at toolchange?
    As serviceman said also, you need to be grounded properly. Look in your manual on grounding. If you cannot get your dealer to fix your problem .. call the factory .. "can't do anything more" is not Haas' motto.
    Jul 2007
    195
    Smile
    I have a VF2SS just like yours. Bought new.
    When we first got it, it was doing the same thing as yours. They do seem to be affected by heat. On real hot days it will screwup once in awile. But what we found to solve the tool changer problem is quite simple. From the factory the speed of the tool arm is set so high that it almost seems like it's going to tare its self to bits and we had alot of tool changer faults like you. I had the tech back the speed down to 80% just a blink slower and all the faults went away. Give it a try. Also see my comment about cold air guns. We don't have a lot of real hot days here so that is not much of a problem for us.
Page 1 of 2 12
  1. VM16 CNC shutting down
    By elecbeaver in forum Milltronics
    Last Post: 05-22-2007, 12:22 AM
  2. VF2SS Ethernet / HD / USB FIX
    By highspeedmike in forum Haas Mills
    Last Post: 04-02-2007, 07:43 PM
  3. Drive shutting down
    By Halfnutz in forum Stepper Motors / Drives
    Last Post: 01-16-2007, 12:42 AM
  4. Replies: 110
    Last Post: 08-17-2006, 03:48 AM
  5. Camsoft CNC Pro- Computer Shutting Down
    By mzartop6 in forum CamSoft Products
    Last Post: 05-08-2006, 06:08 PM
