I recently aquired 3 steppers, Astrosyn Miniangle steppers to be exact model # 34PM-C049 that are labeled as: 1.7V / ph and 4.7A / ph, 1.8 deg/step.
So I'm guessing that if I increase the Voltage in say to 6v this will in turn lower the current needed per Phase .... ?? right ?
The only specs I could find on them was through a cross-refference chart that put them at an output of 180 in oz.
I've been going back and forth on what I want to use as a driver for these, I'm highly considering the stepperworld " Fet3 "unit with the upgraded power transistors, which will run me $152.00. My other thought was to go with a Gecko drive unit like the G201, but from what I've read, I will then need 3 of them ....which will cost in excess of $300.00 which I'm not opposed to spending, but what will they do that I cannot do with the FET3 ?
Any experience with either unit, or helpful hints would be awesome!
btw, if these are good steppers, I can get them all day long @$35 a piece, maybe less.
thanks,
arthur
