588,632 active members*
5,295 visitors online*
    Oct 2005
    29
    Tool Wear Compensation
    I am running SolidCam 2011 on a Haas VF2. When I want to use a sharpened endmill with a smaller diameter, I enter the difference on the offset page of the Haas, but the milled size is still off by the smaller size of the endmill. Is there a setting I need to turn on in SolidCam? Or is this a Haas function only?
    Jun 2010
    you need to use the compensation in your technology page.
    depending on your post it can be offset in wear or diameter offset.
  1. Tool Wear Adjustment
    By nfrees114 in forum Haas Mills
    Last Post: 08-08-2014, 01:04 AM
  2. Tool Wear Compensation
    By rrbmachining in forum Haas Mills
    Last Post: 08-08-2011, 07:30 PM
  3. Dealing with tool wear
    By JTulley in forum Tormach Personal CNC Mill
    Last Post: 11-17-2008, 07:48 PM
  4. Bridgeport interact 520 Wear compensation problems.
    By mustangillusion in forum Mastercam
    Last Post: 03-15-2007, 10:59 PM
  5. NEE controller with reverse wear tool compensation
    By Josh_Petitt in forum Commercial CNC Wood Routers
    Last Post: 10-26-2006, 09:58 AM
