588,199 active members*
4,981 visitors online*
Results 1 to 6 of 6
    Feb 2004
    36
    Question Servo & Load Inertia Ratios
    Has anyone experienced unstable servo operation due to high load/motor inertia ratios?
    I've found several articles on the subject, the best one being:
    http://www.motionvillage.com/welcome...es/Inertia.PDF
    Just wondering if anyone has had some practical issues with this in their past designs?
    Chris
    24220
    Chris, What symtoms are you getting, usually wrong inertia match shows up when you want to move an axis in rapid and a servo goes into overload, or a stepper will stall, there are quite a few programs where you can plug in your numbers and find out, the magic number is usually to keep the motor to load inertia ratio lower than 10:1 . the answer of course is to apply a reduction of some sort, fortunately the ratio is reduced by a squared of the reduction.
    Al
    Albert E.
    Feb 2004
    36
    The machine is not complete. I was just deciding if I should use a belt drive reduction or not to avoid a potential problem.
    The servo's I have are of sufficent torque without reduction.
    I was using Danaher's Motioneering software and if the input's are correct I'm running at about 7.5:1 with the servo's I have.
    The table is very very heavy ~1500lbs but quite rigid.
    Before using the software I was not even aware of matching inertias.
    I was just wondering if this was really significant or more of a theoretical rambling
    Chris
    24220
    Chris, If you want to achieve a certain rapid feed acceleration rate, it is well worth designing for it, I made the mistake a long time ago of winging it and regretted it, I usually shoot for 5:1 now to be on the safe side, and that gives a better margin in case of oversight or the desire to push the acceleration a bit more.
    Al
    Albert E.
    Feb 2004
    36
    Thanks!
    I've put alot of time, money, & sweat into this machine so I should not skimp on the belt/pulley now.
    I just don't have alot of room for a pulley.
    BTW, do you use Danaher's Motioneering software?
    If so do you know what the difference between "slide weight" & "carried axis weight"?
    Also what do you think the GIB force of a 30mm THK is? Or does it even have one?
    Chris
    24220
    Chris, I have used Motioneering, its not bad. as far as I know the slide weight is the weight of a particular axis and the carried axis weight is the the weight of an axis when carried by another axis, this would be like a gantry table where the y axis is also carrying the x and z axis.
    Its a bit like a CNC mill where they ask for the table weight and the max weight carried by the table.
    it seems a bit convoluted.
    Al
    Albert E.
  1. Using surplus servo motors as spindle drive
    By Swede in forum Servo Motors / Drives
    Last Post: 03-16-2008, 02:05 PM
  2. Servo Motor Running away.
    By murphy625 in forum CamSoft Products
    Last Post: 02-27-2005, 08:08 PM
  3. Help evaluating this servo motor
    By WoodSnarfer in forum Servo Motors / Drives
    Last Post: 02-05-2005, 09:51 PM
  4. steppers or servo drives
    By mmjpotter in forum Gecko Drives
    Last Post: 03-30-2004, 09:56 PM
  5. servo motor
    By mace in forum DIY CNC Router Table Machines
    Last Post: 02-08-2004, 10:07 PM
