Hi to all
I'm new on this forum.
I buy cheap china 40W CO2 laser cutter. I need to cut 0.1mm mylar foil.
Problem nr.1: SW witch come with laser is unused. Controller have no speed controll. Well this is not problem. I'll use Pokeys system.
Problem nr.2: I need laser beam max 0.2mm. With original lens I got smallest dot 0.3mm. Can you suggest me witch lens to use ? Meby witch material is better for cutting?
Regards
Simon
