588,390 active members*
5,467 visitors online*
    Aug 2017
    NH4000 Troubleshooting Help
    Earlier today an NH4000 Mill lost all power. Took some time to find the issue but it wound up being coolant that found its way into the mist collectors blower motor which kept tripping the main circuit breaker. The issue I am having now that the mill powers on is it immediately comes up with several alarms:
    SV 1067 FSSB: Configuration Error (Soft)
    SP 1999 Spindle Control Error
    SP 1220 (S) No Spindle Amp
    DS 0650 (B) Pole Detection Request
    I found that the KM0 contactor is not pulling in and so no voltage is being supplied to the PSM. I believe all these alarms are related and that if I can solve the PSM incoming power issue it will likely correct all four alarms, but I am lost at this point. I am not an electrician and the wiring for the coil to pull in this contactor goes back to a printed circuit board. Any help as to what to check next would be greatly appreciated.
    Brian
    Mar 2008
    95
    Check circuit board on lower left of control cabinet there are 3 5amp fuses approx 1" x .25"
    Aug 2006
    162
    Re: NH4000 Troubleshooting Help
    i had a similar problem when there was a chip in a coolant pump plug, we couldnt clear the alarm because the contactor for the pump had actually welded itself closed. you might want to check that the mist buster controls are all functioning
    Sep 2021
    Quote Originally Posted by BrianLWilliams View Post
    Brian
    Hi Brian,
    did you find the source of the problem?
    I´m currently having the same errors:
    SP1220
    SV1067
    The 25V signal to start the Module on the connector CX3 is ok, but it still does not start. I Tried to bridge this signal, and the module starts but the Alarms remains there... must be another thing...
    Any idea?
    Thanks in advance,
    Javier
  1. Mori DCG NH4000 Spindles
    By tminnig in forum Mori Seiki Mills
    Last Post: 01-15-2012, 03:03 AM
  2. Pallet for NH4000
    By dniemela in forum Mori Seiki Mills
    Last Post: 11-19-2011, 09:03 PM
  3. Pallet for NH4000
    By dniemela in forum Want To Buy...Need help!
    Last Post: 11-19-2011, 08:56 PM
  4. NH4000 DCG only uses M speed codes on
    By guitarzycki in forum Mori Seiki Mills
    Last Post: 09-20-2010, 05:39 PM
  5. NH4000 comunication problem
    By hefestos in forum Mori Seiki Mills
    Last Post: 02-09-2010, 04:27 PM
