Hi guys, I have been lurking here on the forum for quite a while now. I don't really have any hobby level experience, I have only used mills and lathes in an industrial production type setting. My skill set is pretty broad. I'm proficient in Mach 3, Mastercam, Bob Cad/Cam, and Solid Works. I remember most of the G&M codes, but with the newer software it's all mouse clicks so that's irrelevant. I can program and operate Mills, lathes, and router tables. Have had hands on experience with Mori Seiki and manual lathes. Fadal, Jet, and Tree vertical mills, both CNC and manual. And Multi Cam CNC router tables. The most interesting thing I have done is when I worked at Ultra Poly, I made some prototype bindings for K2, and I made an aluminum test mold for the McDonalds McGridle sandwich. And we had the contract for the Gator Decking on the Navy ships, so I did a lot of tight tolerance programming. Oh and all the little pink rollers you see at the car washes like Brown Bear, that's my lathe work...simple but still cool to see.
Anyway, I want to buy myself a mill for home use, so I am hoping to get some input and opinions from you guys. I have a budget of around $1500 -$2k for the mill it's self. I will eventually want to convert it to CNC. And, I would like the maximum Y travel I can get for the money. I will admit I don't know much about the hobby mills on the market today, so hopefully you guys will have some good advice for me.
Thanks in advance for any input!!
-Jason
