Working on an idea for a filament winding rig for making carbon fiber tubes and need the technique for calculating the torque required to drive the sled.
The sled runs back and forth a distance of 12' on a pair of square tubes. The sled weighs right at 8 lb and rides on ball bearing rollers. Tension on the filament is 10 lb. Friction loss is only a couple of ounces. Drive is 3/8"XL belt. PD of the 32 tooth drive pulley is 2". I would like to make one 12' pass every 20 seconds.
How do I calculate the right size stepper to handle the torque? I can figure the running torque but how do calculate the acceleration/deceleration torque?
