588,178 active members*
4,208 visitors online*
    Mar 2004
    47
    Babington burner
    I need a pump for my Babington burner. Is a low volume oil burner pump the way to go? It seems like most pumps are 150 GPH and up but there's no way my globe will be able to take a 2+ gallon per minute flood. I know I can choke down theh flow with a valve but it would be nice to have a much smaller pump to begin with.
    Jul 2006
    1062
    Motorcyle engine oil pump will do the trick :idea: Are you blowing the air in? If you are then a suitable reduction between the fan/pump and a means of restricting the air would seem sweet to me hth
    edit) Can you post some pictures as i'm going to build a shed heater from the Babbington patent soon :beer:
    Keith
