587,913 active members*
4,057 visitors online*
    Aug 2011
    Constant Drilling Force
    Has anyone setup a automated drilling machine that applies constant force during a drill operation.
    I'm setting up a machine to do this and i'm contemplating setting up the drill feed axis on an air actuator to ensure the bit experiences constant force.
    Feb 2009
    6028
    Air does not work well. Since the tool will change loads, entering and exiting, you will get a build up of air pressure in the CYl that will release once the drill starts breaking through. This will jam the bit through once the tip penetrates the part. You need something less compressible. Think hydraulic, or air over oil.
    Honestly, now days, it may be cheaper to use a stepper motor with something like arduino to control it.
    Aug 2011
    i am familiar with the arduino boards as i currently use them to control transportation robots.
    How would you control the constant torque on the stepper. from my limited knowledge i thought steppers required step and direction instrustions and you vary the speed by changing the step pulse. Is the torque related to the input voltage on the stepper?
    Feb 2009
    6028
    I believe it would be input current. Voltage would give you speed. I'm a servo guy, not much with steppers.
    Jan 2006
    2985
    Why does the force matter? A stepper wil give you a constant feed which will be pretty close to a constant force.
    Matt
  1. Constant Force Springs
    By rrobb in forum Benchtop Machines
    Last Post: 09-06-2011, 08:23 PM
  2. Spot Drilling/Center Drilling Steel 55 HRC
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 03-11-2009, 07:35 PM
  3. Constant Force Spring for Counter Balance
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 10-25-2006, 03:10 PM
  4. PWM Vs constant current
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 10-25-2005, 10:48 PM
  5. How to make a Constant Force Spring
    By jwvica01 in forum Benchtop Machines
    Last Post: 06-28-2005, 01:17 AM
