Here is one approach.
I like to place my Work Zeroes, the G54, G55, etc locations at the center of my part or at some distinctive feature on the part such as a hole. You have a 1" square so I would choose the center and locate the Work Zero this way:
Put something in the spindle with a known and accurate diameter, this is your probe. Use the jog control to bring this probe down beside the part and jog slowly toward it using either the X or Y axis. Use a piece of paper between the probe and the part to know when you are getting close; just slide the paper back and forth and you will feel it get pinched. Of course you need to be moving in 0.001" steps for this. I know paper sounds crude but it is surprisingly precise at around 0.003" and you can always measure it with a micrometer. When the paper is pinched so that it can barely be moved without tearing your probe is about 0.002" from the part. Now for safety raise the probe above the part. The centerline of your spindle is now a distance away from the center of the part that is the sum of the radius of the probe + half the width of the part + 0.002" for the paper. If you have approached from the positive side you need to subtract this sum from the machine coordinates that are displayed for the current location of the probe; you make the distance more negative. Now you enter the result into the G54 Work Zero table for the axis you were doing then repeat everything for the other axis.
At the end of this your Work Zero is placed at the center of your part.
For the tool offset, the Z offset I nearly always use the top of the part and you find this by brinning the tool down carefully and use the paper again and then this machine coordinate position goes in the Z Tool Offset table.
Tool Compensation how does it work?
First consider writing the program without tool compensation: You have a part where the edge is 0.500" from the G54 Work Zero location in all directions. You want to go around this part 1/8" or 0.125" in from the edge or 0.375 from the Work Zero at the center. Let's say you are using a 1/4" cutter so the radius is 0.125". for the periphery of this cutter to be at the 0.375" poition from the Work Zero the center of the cutter must be at 0.500". So if you are starting at the bottom left corner you start at X-.5 Y-.5 and then move to X-.5 Y.5 then X.5 Y.5 then X.5 Y-.5 and back to X-.5 Y-.5 of course during this your Z position is Z-.1. Notice these moves are climb milling.
With Tool Compensation you do not add the tool radius into your coordinates you write the program using the actual part coordinates; i.e. X or Y + or - .375. Then you enter into a Tool Diameter table for the Tool number either the diameter of the cutter or the radius depending on what your control works with and in the program you have a command G41 D01 which tells the control "for this tool use the entry in location D01 and figure out the correct moves to put the periphery in the correct place for the following coordinates in a manner such that the tool centerline is to the left of the direction of movement".
Your 1" square is very simple but when you get to more complicated moves Tool Compensation means that some moves are not possible because they are shorter than the tool radius. Also with Tool Compensation you cannot reverse direction because the controller is trying to keep to the left of the direction of travel. When you reverse it will either try to move acros the cutline to the opposite side so it is on the left and this makes a big crunch; or it puts up an alarm.
Good luck.
