587,189 active members*
2,512 visitors online*
Thread: Artcam 2008
Page 1 of 5 123
Results 1 to 20 of 87
    Dec 2008
    441
    Red face Artcam 2008
    Hello.
    I`m Norwegian, so my english isn`t so good, but i try my best!
    I use artcam 2008, and i try to make toolpath to a spider, but i get 3 errors.
    When i group the vectors, i got the same error again, it didn`t help...
    Can someone help me a little bit...
    Greetings from Robert.
    Attached Thumbnails Attached Thumbnails Uten navn.jpg   Uten navn1.jpg   Uten navn2.jpg
    My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
    Looks like you need to carefully go over the vectors and clean them up. It's telling you that some are open, and some are overlapping. When you fix them, you shouldn't get any errors.
    Dec 2008
    441
    Thanx for the answer Ger21.
    But all the vector is made in AutoCAD with polyline, and exploded after i`m finish.
    I try to open DWG with polylines, but i got the same error.
    Robert.
    Feb 2007
    4553
    Post
    Vegabond,
    Check the vectors with the vector doctor utility built into Artcam.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Dec 2008
    441
    Hello.
    I try that now, and clear the point`s, but i got the error again.
    Here is a picture.
    Edit, i mark all vector ( ctrl + A) and then go in to doctor.
    Robert.
    Dec 2008
    441
    Hello again.
    I need help to add some bridges to my drawing. I only find "bridges" in the "profile options"
    Some tip?
    Robert.
    Feb 2007
    4553
    Post
    Robert,
    The only automated way to add bridges is in the profile options.
    If your work is similar you can design a relief that you would merge into your model or just manually add raised shapes "sections that you cut out after machining" that will hold your work.
    Jeff...
    Dec 2008
    441
    I have not using artcam so much, just to 2d things. Do someone now video tutorials with "voice"
    And i can`t make an relief....
    Robert.
    Dec 2008
    441
    Hello again.
    I have a problem again.. When i try to carve (V-Bit carving) i can`t run on centerline. When i generate toolpath, it came many lines in each letter.
    How do i just use the senterline? sometimes i make it, and sometimes not....
    Some tip?
    Robert.
    Feb 2007
    4553
    Post
    Robert,
    You need to use a single line font.
    Jeff...
    Dec 2008
    441
    Thanx Jeff..
    But what did you mean? how do i do that?
    Thanx again.
    Robert.
    Feb 2007
    4553
    Post
    Robert,
    See the attached picture for more information.
    Jeff...
    Dec 2008
    441
    Maby it is the size of the letter`s?
    When i use big letters (25mm), i cant carve with only one line, but is the letter`s smaller (10mm), i can.
    Im a little confused.... :P
    Thanx for the help.
    Robert.
    Attached Thumbnails Attached Thumbnails Test #01.jpg   Test #02.jpg   Test #03.jpg   Test #04.jpg
    Feb 2007
    4553
    What do you mean by "you cant carve" ?
    Please provide more details.
    Dec 2008
    441
    Ok, sorry, i mean i can`t carve with only the senterline, it came many lines. And the cnc is using much more time to carve many lines in one letter.
    I figured out that when i try to make smaller letter`s, it came just a senter line, but when i write bigger letter`s, it came many lines...
    Understand?
    Thanx. Robert.
    Feb 2007
    4553
    Post
    If Artcam needs to make multiple passes to cut out a font it is not a true single line font.
    If the cutter width is not as wide as the toolpath it needs to make multiple passes.
    You need to use a single line font or a larger diameter cutter if you want to save time.
    Dec 2008
    441
    Yeah, i see that now...
    Can i just carve the outside of the letter`s ? do i have to use the 2d profiling then ?
    Robert.
    Feb 2007
    4553
    Feb 2007
    4553
    Dec 2008
    441
    Thanx, i have been to their side, but i haven`t seen theese video.
    Many thanx, i came back with more questions
    Nice to have forum....
    Robert.
Page 1 of 5 123
  1. CncBrain SDK - VB.NET 2008
    By Switcher in forum CNC Machine Related Electronics
    Last Post: 12-11-2011, 06:20 AM
  2. Artcam 2008 -Noen som bruker det?
    By Vegabond in forum Norwegian
    Last Post: 04-01-2010, 07:09 PM
  3. CWX SP2.1 for 2008
    By pixburghenat in forum CamWorks
    Last Post: 05-16-2008, 09:39 PM
  4. ArtCAM Insignia 2008 now available
    By Beckyf in forum News Announcements
    Last Post: 04-02-2008, 03:12 PM
  5. Learning SW 2008
    By SPEEDRE in forum Solidworks
    Last Post: 01-29-2008, 07:30 PM
